Dan Case A4 with 7900X, Asrock x299 itx, 32 GB ram and a FTW3...
KDC
27
Reactions: D10S
galletabah
136
88
I've found those too. But to me they do look a bit to tall compared to the original ones from the Dan case. Thought about buying a set just to check since the price I found was just about $5 for a set of 4. But with shipping and toll I am looking at $40ish for a set containing 4 pcs.. Kinda steep
are the same than ncase m1
You can buy it in sfflab
D10S
123
121
Yes, probably need a modd,
i'll buying for you and let you know if they works,
here in Italy i can grab it just for 5€ (waiting 4/5 days)
And thanks to @galletabah for the usefull information!
Reactions: galletabah
KDC
27
Gotta love this community :) I've just ordered from sfflab, but please let us all know if the jt03 kit actually fits the Dan.
galletabah
136
88
I use it in a mod for a ncase m1, and no, the panels dance a lot a dont stay in his natural position. I dont know why because the piece is aparently the same.
Reactions: D10S
D10S
123
121
This piece scared me at first sight,
it would be better if there were at least 2 spare parts included in the kit!
The fact that you can break all 4 at the same time is a big problem! :\
KDC
27
To be honest they did feel really really stiff and brittle to begin with.
I hope the ones I ordered will be a little more "workable" since these original were super stiff and they mostly fell apart just by removing the side panel :/.
I had the Ncase before and with a year or so of traveling and upgrades more or less every 3rd month those clips never gave up. I do know that my specific case sat in its box in a basement for quite a long time before I got hands on it, but the seals were not broken so I doubt it would be something like sun exposure that would have weakened them. Again hoping the new ones will be a bit more "workable"
