DAN C4-SFX
tangoak
Building new rig on black friday too but I am going to buy a temporary case. I still have to choose GPU.
What 2.5 slot Radeon RX 5700 XT should fit in the C4 as I am not sure what 2.5 slots is in cm?
dondan
DAN Cases
938
2,934
Currently there are no specs release for the C4-SFX I am working on. The specs in the first thread post are wrong. Furthermore you will have to wait minimum 6 month from now on before you can hold the case in your hands. But to answer your question: The case has two possible GPU mount points horizontal or vertical.
Specs for vertical (sandwich): Length: 300mm Width: 3 Slot Height: 150mm
Specs for horizontal (classic): Length: 300mm Width: 2.75 Slot Height: 115mm
*There is no guarantee for these specs.
Jetpack_Maniac
How does the new case design compare to the old one? It sounds like it changed a bunch since the renders were posted. I'm also really excited to see how this turns out. My next system will be SFF and I want this case to be the one I use.
Tazul97
Mar 5, 2019
Does this mean that you DONT plan on the C4 being compatible with the high end "ASUS STRIX" series cards which sits at 305mm in length?
newzealot
23
I see.... a completely different design that you start from scratch?
Bonusround
73
59
Read upthread — the vertical-or-horizontal GPU choice is in keep with the last iterations @dondan shared here.
Dan, thank you for this update. There are many promising SFF cases newly available or coming on line soon, but I'm willing to wait a bit in order to learn more about this refined C4.
Please share more as soon as possible – but no sooner. ;-)
Dahmos
Moin!
Thanks god DAN is alive... and C4 also :-)
6 Month - ok, still fine for me. I´m planning to build a new rig in late 2020. Is there a newsletter or something wich keeps me updated when C4 is ready for pre-order?
Navic
49
45
The CAD work is done :) Now I start creating renderings :)
Even though I'll probably end up going with the Sidearmd, congrats on finally "finishing" this project! I say "finishing" because who knows what tweaks you'd want to make, and that's not even getting to the production side of things. Again, congrats and good luck on the rest of your endeavors!
Reactions: fabio
