Card | Sandwich | Classic |
ASUS ROG Strix GeForce RTX 3080 | fit | not fit (length, height) |
ASUS ROG Strix GeForce RTX 3080 OC | fit | not fit (length, height) |
ASUS TUF Gaming GeForce RTX 3080 | fit | not fit (power socket)! |
ASUS TUF Gaming GeForce RTX 3080 OC | fit | not fit (power socket)! |
EVGA GeForce RTX 3080 FTW3 Gaming | fit | not fit (height) |
EVGA GeForce RTX 3080 FTW3 Ultra Gaming | fit | not fit (height) |
EVGA GeForce RTX 3080 XC3 Black Gaming | fit | fit |
EVGA GeForce RTX 3080 XC3 Gaming | fit | fit |
EVGA GeForce RTX 3080 XC3 Ultra Gaming | fit | fit |
Gainward GeForce RTX 3080 Phoenix | fit | fit |
Gainward GeForce RTX 3080 Phoenix GS | fit | fit |
Gigabyte Aorus GeForce RTX 3080 Master | fit | not fit (power socket)! |
Gigabyte Aorus GeForce RTX 3080 Xtreme | fit | not fit (power socket)! |
Gigabyte GeForce RTX 3080 Eagle OC | fit | fit |
Gigabyte GeForce RTX 3080 Gaming OC | fit | fit |
INNO3D GeForce RTX 3080 iCHILL X3 | fit | power socket height! |
INNO3D GeForce RTX 3080 iCHILL X4 | fit | power socket height! |
INNO3D GeForce RTX 3080 Twin X2 OC | fit | fit |
MSI GeForce RTX 3080 Gaming Trio | maybe if it fits through the front hole | not fit (length, height) |
MSI GeForce RTX 3080 Gaming X Trio | maybe if it fits through the front hole | not fit (length, height) |
MSI GeForce RTX 3080 Ventus 3X | fit | maybe with lp power connectors |
NVIDIA GeForce RTX 3080 Founders Edition | fit | fit |
Palit GeForce RTX 3080 GamingPro | fit | fit |
Palit GeForce RTX 3080 GamingPro OC | fit | fit |
PNY GeForce RTX 3080 OC XLR8 Gaming | fit | fit |
PNY GeForce RTX 3080 OC XLR8 Gaming Epic-X | fit | fit |
Zotac Gaming GeForce RTX 3080 Trinity | fit | fit |
'Flipped' is only relative to Classic Layout - I'd argue that for sandwich layout, 'Flipped' should be actually considered default.I wanted to run my ftw3 ultra in sandwich mode anyways ! Kind of bummed that I would need to flip my case for the radiator to be at the top but no biggie.
Here is the updated table the ROG will fit in sandwich:
Card Sandwich Classic ASUS ROG Strix GeForce RTX 3080 fit not fit (length, height) ASUS ROG Strix GeForce RTX 3080 OC fit not fit (length, height) ASUS TUF Gaming GeForce RTX 3080 fit not fit (power socket)! ASUS TUF Gaming GeForce RTX 3080 OC fit not fit (power socket)! EVGA GeForce RTX 3080 FTW3 Gaming fit not fit (height) EVGA GeForce RTX 3080 FTW3 Ultra Gaming fit not fit (height) EVGA GeForce RTX 3080 XC3 Black Gaming fit fit EVGA GeForce RTX 3080 XC3 Gaming fit fit EVGA GeForce RTX 3080 XC3 Ultra Gaming fit fit Gainward GeForce RTX 3080 Phoenix fit fit Gainward GeForce RTX 3080 Phoenix GS fit fit Gigabyte Aorus GeForce RTX 3080 Master fit not fit (power socket)! Gigabyte Aorus GeForce RTX 3080 Xtreme fit not fit (power socket)! Gigabyte GeForce RTX 3080 Eagle OC fit fit Gigabyte GeForce RTX 3080 Gaming OC fit fit INNO3D GeForce RTX 3080 iCHILL X3 fit power socket height! INNO3D GeForce RTX 3080 iCHILL X4 fit power socket height! INNO3D GeForce RTX 3080 Twin X2 OC fit fit MSI GeForce RTX 3080 Gaming Trio maybe if it fits through the front hole not fit (length, height) MSI GeForce RTX 3080 Gaming X Trio maybe if it fits through the front hole not fit (length, height) MSI GeForce RTX 3080 Ventus 3X fit maybe with lp power connectors NVIDIA GeForce RTX 3080 Founders Edition fit fit Palit GeForce RTX 3080 GamingPro fit fit Palit GeForce RTX 3080 GamingPro OC fit fit PNY GeForce RTX 3080 OC XLR8 Gaming fit fit PNY GeForce RTX 3080 OC XLR8 Gaming Epic-X fit fit Zotac Gaming GeForce RTX 3080 Trinity fit fit
I will not change the size of the case.
Maybe you didn't know of this:
Why no AMD 6000-series cards on the list...?Here is the updated table the ROG will fit in sandwich:
Based on red devil 6900xt specs, 320mm*135mm*62 mm, seems like it will fit. The merc 319 probably will not fit as it's 330mm long. The vanilla xfx, sapphire reference cards etc should fit as they do also fit in the ncase m1.Why no AMD 6000-series cards on the list...?
Thanks for the response, much appreciated!
Is it Friday yet?!yes
@all
I will have sample pictures on Friday![]()
IIRC Q3-4 2021But when can get it?
