So here is the full answer on the puzzle:
With this hole you are able to mount a 750W Corsair SFX to the front. You need 4x 10mm C6-32 Standoffs. This enables you to mount the new Asrockrack Epyc FAT-ITX board.
A config like this is possible:
64C/128T Epyc
Dual 280er Radiator
Nvida Quadro RTX A6000 48GB
I know the usecase is nearly zero but it will result in an epic/epyc build from Linus. This is why i call the hole LTT.
64C/128T Epyc
Dual 280er Radiator
