DAN C4-SFX
Igor_B
45
@dondan just a small appreciation from the community for your release next year. One question - Did you think about a limited 13.37L batch for those who want a smaller case?
Igor_B
45
@dondan Do not want to sound like the boy from the airplane bus in "Home Alone" movie, but ... please answer these:
  1. Manual shows only the RTX 3xxx series 45 degrees power cable and not the RTX 4xxx series. Do you think that CableMod angled 12vhpwr adapter is compatible with your case so that it would not interfere with the side panel?
  2. Corsair Dominator DDR5 2 sticks with Noctua D12L and Noctua NF-P14s on the side panel compatibility. Or only 32mm LP-RAM 32mm as Crucial DDR5 will fit? Please confirm/correct
  3. Can you plz refresh the GPU compatibility list with hyperlinks to the official websites’ products? This would make your community happier and less questions asked about the exact GPU
Thank you!
loosen
If you install a 3.9 Slot card you cant add fans on top. If you install a 3 Slot card slim 140mm or 120mm fans will fit on top. In total you will have 80mm. If you install a 2.7 Slot card you can add normal height fans on the card.
dondan
DAN Cases
1,981
8,392
Thank you!
1) The 90° will not fit and the 180° will interfere with side mounted radiator or fans. Just use the Corsair 12VHPWR gen5 cable for their SFX PSUs and it will fit. Or usw one of the CableMod Silicon cables.
2) It depends on the fan configuration on the D12L. Its not a limitation of the case its of the D12L. Check out Noctuas product page.
3) I do not think this is necessary.
tal133
Are you referring to these cables?
Reactions: dondan
dondan
DAN Cases
1,981
8,392
It depends. Many of these half sized mATX will fit like:
2 Slot mATX (19.7 cm x 18.8 cm) like:
ASRock H610M-HVS
3Slot mATX (23.0cm x 21.5cm) like:
GIGABYTE H610M S2H DDR4
all of these will require to mount the PSU in the front position!
Only full 4 Slot mATX (24,4cm x 24,4cm) will not fit! But there are many chinese cases that will fit 4 Slot in 15l but will have many other limitations.
warspitebattleship
29
Chinese cases do not have limitations. You can choose everything you want. Zillions of them. The only crucial difference is manufacturing quality.
Forget itx, it is dead in classic layout by GPU size. M-Atx is new normal.
Do not waste time. Make compatible and go.
  • Angry
Reactions: DrHudacris
ironwilly
Such passion, such well formed arguments and facts, I am sure Dan will be moved to tears and will scrap all progress so far just so he can accommodate your desires and even send you a free case in the end just to thanks you for the grace bestowed upon us with your comments. We are truly blessed to have you here warspitebatleshit.
dondan
DAN Cases
1,981
8,392
Many of these chinese 15L mATX cases have many limitations for CPU cooling or GPU support. The only way to do mATX in 15L and support RTX 4080/4090 is a sandwich based layout.
The smallest possible mATX case including the following features:
- classic hardware layout
- 280 AIO support
- tower heatsinks up to 145mm in height
- SFX and SFX-L support
- GPU with an height up to 145mm (like RTX 4080/4090)
would be 166 x 271 x 390 (WxHxL) = 17.5 L
I think the right way to do mATX is with ATX PSU and 360 AIO support. With the A3-mATX i have a case with these features in the pipeline.
The C4-SFX will go in production next week so the time for feature requests is over. ;)
