Based on some of the above reading, is seems 8mm heatpipes is way more efficient than 6mm; not sure why that's so.
https://smallformfactor.net/forum/threads/cpu-gpu-coolers-and-heat-pipes.1690/#post-40826How does one bend heatpipes? Google wasn't very helpful to me.
Has anyone tried 3D printing an Aluminum heatsink? If your case is sufficiently small, you could even combine the chassis of the case with the aluminum fins. Maybe you could use that copper block linked above and bend your own heat pipes and have them go into the aluminum. It would be expensive, but it might save a massive amount of time because then all you need to do by hand is bend and affix the heat pipes. I don't know how the thermal properties of 3D printed aluminum will be but I've read that DMLS printing results in metals with nearly the same properties.
Ah ok, its good to know.3D printing aluminium is unaffordable; here's a shapeways' price of a 100*100*40mm heatsink I quickly sketched:
The problem with 8mm pipes and why you don't see them more in our part of the world is that the minimum bend radius is pretty huge. In order to not kneecap the pipe's performance, I believe you need a outer bend radius of at least 5-6x the width of the pipe. In the case of an 8mm pipe that is 40-48mm.
In theory yes, but good luck finding one manufactured that way.What about an 8mm heatpipe that split into 2x4mm pipes during the bend section, and then returned to an 8mm after bending?
It would still bottleneck around the bend, but maybe less so?
I dont really get the idea of clamping pressure. Too little cpu pressure will harm the cpu? Should I get some fancy spring screws?Sure, make it yourself or have someone make it for you. It definitely looks to be a 2D profile, so it should be too hard to duplicate it in copper. You may want to make it thicker than (what appears to be) the aluminum clamp to maintain mechanical properties. If it is steel, you'd want to make it even thicker to make sure you have sufficient clamping pressure on the CPU.
