Discussion Coolant Colors
Jp42nca
94
I did a custom water cooling for my open air pc just over a year ago and went with clear coolant because I read that color pigments can clog a water block & radiator over time & I just didn't want to deal with yearly flushing my system. Sooooo looking at my res is pretty blah 🥴 clear coolant isn't really enticing to look at. Sure would look nice with a bit of color swirling around.
I've seen some coolant that have pigment in it and swirls around in the res, looks really nice, kinda mesmerizing. Has anyone developed one that doesn't clog your water block & radiator? I think the answer is probably still no but need to ask.
Thanks for reading my post.
Streacom 6A XL, ASUS Z690i, i9-13900K, Corsair Dominator Titanium DDR5 64GB, ASUS GeForce Dual RTX 3060, Samsung 990PRO 1TB 'C' Drive, Storage Samsung 990PRO 2TB, Windows 11, Corsair PSU SF750, Alphacool Eisblock XPX Pro Aurora Full Brass-Chrome CPU Water Block, Alphacool Rise Flat Reservoir D5 w/VPP755 Pump, Alphacool 280mm Radiator V.2 NexXxoS ST30 Full Copper w/ be quiet 140mm fans
7,730
From experience, I've only used the Cryofuel White coolant when not using distilled, I've only had block clogs, never rad. In saying that, I did run the coolant for over a year before servicing, and the blocks affected were cheaper Byski units.
Reactions: Jp42nca
Jp42nca
94
I went with Alphacool all the way, used their clear coolant. I've been looking into it more & doesn't look like any mfg has remedied the issue. It's a fluid with colored particles running through out, I don't see how they can change the viscosity. The best they have come up with is a water color additive that changes the clear coolant to a color. I spend to much money on my system to tear it apart every year & try to clear out the gunk, not going there.
Thanks for responding.
