(COMPLETE) SFF Inception: NFC Skyreach 4 MINI Brickless Build Log
2,195
2,212
Norway
thank you for the link, I'll have to consider getting into this, right after I'm done learning some soldering skills.
Crimping wires is easy compared to soldering. I won't say I'm particularly good at it, but I was able to crimp perfectly passable and durable connections within a few minutes of first picking up the tools.
Reactions: CubanLegend
morj
366
698
Germany
What is the volume of the S4M with the side panels offset 5mm each? If my calculations are correct 348mm x 225mm x 74mm is around 5.8 liters...
