Just a sketch of this balls-to-the-wall idea...
A case supporting two dual slot graphics cards (given that a mATX board can be found with the right pcie slot pitch
), and where you can mount dual 360mm radiators, and a SFX/SFX-L PSU.
The case is vertically oriented with a footprint of 25.5cm (depth) * 17.7cm (width)
Now, I really don't have much experience with liquid cooling (you can probably tell from the absence of a pump or reservoir on the renders), but intuitively it seemed like a possible solution for cramming two radiators in the space above the motherboard would be to have them facing each other, so that the warm air coming out of each would join on the middle and exit the case from the top, like a chimney. Or maybe that's a terrible idea.
