• Hey Guest, save 20% on our entire merchandise range during the month of December! Use promo code MAKEITSMOL at Our Merchandise Store!
Concept Idea Dump #2
Which case is best?
  • Option 2: 20.5L thin tower with support for a 420mm AIO or a 280mm radiator in a custom loop.
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
mwal
26
Back at it again, but this time, I figured out how to make my larger cases substantially smaller, without too much compromise. So now here are those ideas with a slight redux.
16.6L tower has been eliminated as a viable option. All cases support:
SFX-L PSUs up to 125mm long.
mATX and ITX.
Liquid cooling and air cooling (Air cooling not recommended, but available).
120mm case fans.
Options 2 and 3 have:
Support for single/dual/triple fan AIOs, and single/dual fan radiators in a custom loop (pump/res combo mounted on third fan/rad slot)
Support for up to 38mm thick radiators and 25mm thick fans.
Make sure to read this clearly before making a choice.
mwal
26
PS: The volume measurements do not account for panel width, they only account for internal space.
