C-WS with clean unibody and tempered glass panel.
I chose the original model he displayed too - with the same colors and everything. Black with a white unibody, but that unibody is the fine grain and looks great.
http://www.ebay.co.uk/itm/Sintech-P...10-30cm-FPC-Cable-molex-for-GPU-/321362865132
This will be the best solution - most of flexible risers have 2-2,5A - 25-30W. - can delive 75w, but how long?![]()
Hmmm, what's the price on this?![]()
The hdplex riser is, however only 15 cm long. For the Catz C-1 you need at least 25 cm. I will order the Lian Li riser and test myself. There seems to be a lack of testing in regard to this issue. The 3M riser is used in the DAN-A4 and I didn't see anyone saying you must use a card with additional power connectors.Probably better to ask - what risers have you found in your testing or reading that can reliably handle 75w? That is an interesting question that I never really considered. Do the expensive 3M and Lian Li ones successfully manage this? I know the HDPlex riser has been seen to do it, but it is not in stock in Europe at the moment.
A moment ago I get the first batch form powder coating. Some photos in few hours![]()
A lot depends of cost tempered Glass panel. With standard aluminium side panel cost will be very close to C-SFX.Hmmm, what's the price on this?
CATZ C-1
0001
pure white unibody, and pastel blue core.
Pure white unibody graphite black core. Yes, It's yours @bledha![]()
