New project?
possible smaller version for flexATX or hdplex 300W, but sfx is the most common in my opinion.
Very keen to order a unibody case, love that both the CPU and GPU face the same side, but would like to see some build logs before I commit @bledha maybe?
any chance of an .STL (or other file format) containing the Catz C-1 with the Unibody to test builds and color beforehand? Could always mock something up myself to approximate the shape of this case but will only do that if I need to. Choosing the right color combo is harder than I thought.
Exactly my idea, except with the 1070 Mini instead. Thanks.seeing if the new hdplex 300w internal ac-dc converter will fit with my EVGA 1060 6gb in the case.
If there´s no luck, you can try the super dirty but quick photoshop
PD: Your eyes gonna bleed, but it´s something made fast being too lazy with the program
Trying to find the best solution for shallow case - 200-230mm depth with internal psu. I want to make something new, not just similar layout to existing projects.
8L, sfx,sfx-l,flexATX, CPU cooler up to 60mm, gpu with sfx 180mm, with flexATX 250mm, motherboard panel on bottom.
9L, sfx/sfx-L, CPU cooler up to 100mm, gpu 250mm
In 9L gpu is in pci-e slot.I would have considered that 8L one before the C1 if it were conceptualized before. The designs are nice, and the integration of the SFX PSU is nice as well - one with HDPlex options around 6L would be nice, allowing for a bigger GPU and maybe an internal AC-DC set up.
That 9L render, that is some PCIe riser gymnastics that would need to be done!
