remember
That is my problem today - I do not remember anything at all and am leaning on others to think for me! Thanks.
remember
Hi, I'm accepting orders for second bath to 13.03. So realization time is 31.03.
On Monday I'll get cores, and probably Friday unibody. Next powder coating and 17.03 or 20.03 shipping.Glad to see things are going well! How is the first batch coming along?
Yes... i think i have to put this option in order formSorry if this has been asked before, but can you order a version without the optical drive cut out?
Between vents and unibody is 1cm space, and there's no problem with flow. For now I'm not planning any core modifications - eventually its possible to make front panel on cnc with round break corners.I think the case is great, and really fills a spot the S3 Mini left behind. I had a design question though. I think aesthetically it looks great with the unibody front. Unfortunately this increases the bulk a tiny bit and covers up the vents on the sides.
With the original case, without the unibody front, Is it possible to have curved corners in the front instead? You could use longer screws on the sides with the pavrum modding cubes to deal with the the front corner curves. This way you get a case that is a bit more sleek and not as sharp to look at.
First prototype of Catz C-WS core. Side panel honey comb just for show another option for vents.
