Stalled Catz C-1 (5L), C-SFX (10L) and C-WS (15L)
br3nd0
307
297
Toowoomba, Queensland, Australia
The Accelero cooler came in and it fits the 1080 fine However its a true pain to install as you have to tape up a lot of components on the pcb and apply a thermal adhesive to fit the heatsinks(I got some paste in a nook and now I have a bit of coil whine). Overall its a frustrating process. That being said, it has to be the most silent cooler I've ever encountered. At 2000 RPMs its as loud as the stock cooler at idle. I ran into some issues testing it as my room temps were fluctuating so I don't have a true comparison but the Furmark tests I ran had it at 56 C max (21 C ambient).
Great to see your feedback on the cooler, looks promising for my build. Any photos? Interested to see what ram / other heatsinks needed in addition to this cooler.
Cheers
Grafite
3D Printing Enthusiast
Feb 20, 2017
56
50
Atl
Cheers
I can definitely produce some pics, but give me a few days as I am waiting on new thermal adhesive to come in and I can't attach the heatsinks without them. The box comes with basically everything you need, but as @Runamok81 suggested to me, get better thermal glue.
Reactions: br3nd0
Weredawg
119
162
I think the Catz-C1 is going to need a revision. I can barely fit the powerconnector to my gpu, which means that any card wider than the 1080 mini will not fit (Gigabyte 1070).
Guess I'll have to wait on a revision or go with a different case since the Gigabyte 1070 Mini was my decided card. Thanks for confirming this.
br3nd0
307
297
Look forward to it, I wonder also what a bios mod would do to help with temps/general running of the card with this aftermarket cooler as per https://smallformfactor.net/forum/threads/zotac-gtx-1080-mini.1116/page-6#post-32328
E
Elitist1
Guest
It's been over 2 weeks now. If he doesn't get online tomorrow (Monday) then I think it's time to start looking for a new case. I'm really liking the Custom Mod ones.
agreeing with you
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
Texas
Failure to notify customers of any kind of delay or absence really isn't great. Things happen, and it's not always possible, but still.
Reactions: Jonny727272
E
Elitist1
Guest
First @1461748123 for G-Unique (thank goodness guryhwa is still active and responsive) and now @amitoza.... things aren't looking good, this was going to be my HTPC case.... watching this thread with great interest. I wonder if he has a partner or similar who can continue the project / orders.
i wonder this too
Reactions: br3nd0
amitoza
93
258
Sorry everyone! I was on honeymoon in mountains and there was completely lack of GSM network :(
I had 10 orders in second batch and before leave I was able to sent just 7 of them. last 3 will be send tomorrow. I was plan to put here this information about 2 weak ago but I didn't expect problems with network.
For now I stopped accepting any orders because like Grafite said project need some changes. there will be change in order process to, because actual does not work like I expected.
There will be standard option and custom. I have plan to order about 20-30pcs C1/C2 at once and make less colour options to reduce realization time to minimum - some colours are not in stock so sometime I have to wait 2-4 weeks for import it from provider. Realization of laser cut have sometimes 2weeks delay to, when company have a lot of other bigger orders, so I have to make this changes.
Ordering custom options will be unchanged - but realization time will be changed to 6-8weeks.
Grafite
Feb 20, 2017
56
50
Atl
Well first off congratz man! I'll be working on a build log this week and give you some insight while doing so. Your case is great, just needs a some minor revisions here or there to be compatible with a lot of hardware. But I like the changes, really good to see you making adjustment off the community feedback.
