This is inspired by those DIY aluminium test benches and the Geek (Specifically, the A30) SFF case. I want to make a SFF case using those aluminium extrusions. I have a design in my mind but I don’t know how can I do it or what are the tools/parts I should have.
What I also want to do is to mod(like adding some more extrusions) the test bench that also use an aluminium extrusion.
And the design in my mind is like those tempered glass or mesh front PC cases but in a SFF case scale.
Nearest example is like putting 2x 120 mm or 140mm fans at the front of a PK39 or Velka 3. the case's width is almost like the fan's size but the height and length are the same. K39's dimensions are 220x180x100 mm(if im correct) but instead of 100 mm, it will be 120mm to accommodate a 120 mm fan and 240 mm to accomodate 2x 120mm fans stacked to each other and because of that, the height would be 240 mm instead of 220 mm(of course there is some allowance on everything oso the fans will fit but I dont know how much yet). The layout inside is pretty much the same as those sub-5 liter SFF cases(like the the cases I mentioned earlier) where the motherboard and the graphics card is placed back to each other. What I see here is that with the 120 mm width, I could adjust the the CPU cooler height so it could accomodate a Wraith stealth cooler without removing its shroud and any CPU cooler near its height. There is no room for top fans as the fans are now at the front and ITX motherboards only 2 or 1 spare fan headers plus, I won't be adding a fan controller in it as it might have no space but I could be wrong.
The PSU will but either a FLEX PSU, a Pico PSU or HDPLEX, or a SFX PSU(I doubt there will be room for the SFX PSU but if the
The GPU length will depend on me. I am a causal gamer like I don't AAA games because I don't have any hardware to play that and I don't have money for making a PC just to run those games so I think the 180 mm length is enough for me since I could put a 1650 Super in it.
Any tips?
Any tips?
