buying stuff for an S4 mini and I dont even have an S4 mini
VisualStim
431
211
kill me :/
but going
ASUS ROG STRIX Z270I
G.SKILL TridentZ RGB Series 16GB
Intel 6700K
Intel 600p 256GB m.2 (Windows 10)
Samsung 960 EVO 250GB m.2 (Sierra)
Seagate 2TB Barracuda (will replace with SSDs)
G-Unique 400W
Maybe R9 Nano or if any ITX 500 series cards come out with more than 1 DP port :/
zovc
852
603
I could be mistaken, but if I remember correctly, the R9 Nano does not play nicely with pretty much any S4 Mini-friendly power supply setup. It has to do with how drastic the spikes in power draw are.
It's possible that, since people found this out, that either suitable power supplies have come out, or that the newer versions of common ones have been updated to be able to handle it. I know HDPLEX makes updates to their units pretty frequently.
That said, I'm also pretty sure that the 1070 is a more powerful card and a cheaper one. (Unless you already have the R9 Nano of course.) Though, being completely honest, seeing people tune their video cards in AMD's recent software (Wattman and Chill) makes me wish there was a Red Team card that was on par with and a similar size to the smaller 1070's. And Freesync monitors being so much cheaper... hopefully I don't have too much buyer's remorse when Vega drops.
3,381
5,936
45
Victoria BC Canada
The Dynamo will work the the R9 Nano, but you'll definitely need to use the Merge to run dual AC-DC units for the thing. It's a beast.
