Building eGPU Using Oculink, How to Mod the Nano PSU to Type C Female?
codearm2
I'm building an eGPU based on an Oculink connector.
Here are the parts I'm using:
1. Oculink - NVME + the GPU Board
2. PICO-BOX DC-ATX power supply
I haven't tried it yet since the products are still on the way from China.
What I want to ask is whether I can power a single slot card like the RX6400LP.
My laptop is a Dell 7210, which still uses PCIe 3.0.
Also, I want to use a Type-C to power the entire eGPU setup with a 230W GaN charger.
Besides the decoy USB to barrel jack, is there anything else I need?
Thanks!
codearm2
I own several GAN charger at my office, home, apartment so no need to carry single 240w SlimQ, also I want to use things I already own
REVOCCASES
REVOCCASES
Apr 2, 2020
2,074
3,353
www.revoccases.com
sure, makes sense... just saying, because I previously tried with a "normal" GaN Charger but had some issues with this Type-C to 20V DC setup. the SlimQ worked much more reliable for me.
I was using a GTX 1650 in my setup and it would just crash on higher GPU loads, but since you are using a lower powered RX6400, maybe it works for you... good luck!
