I am logging this build as a viewable or downloadable Brickless B550 mini-ITX Ryzen5-4650G PDF file with high-resolution pictures.
Try clicking the PDF file link (above) if you would like to view the build log with high resolution pictures. Tip: When viewing in a PDF Reader find the -/+ controls at the bottom of your window and expand the PDF file for better views of the high resolution photos.
Components:
Components:
- $157 GIGABYTE B550I AORUS Pro AX Socket AM4 AMD (B550IAORUSAX)*
- $74 K39 Case (47mm CPU cooler height)
- $28 (server/Flex-ATX PSU), Delta DPS-350AB-12A/Intel FHJT350HEPS 350W Power Supply
- $242 AMD Ryzen 5 PRO 4650G 6-core, 12-Thread
- $69 2x8GB of the purple ADATA PC DDR4 2666MHz VLP-RAM (very-low-profile)
- $157 Samsung 970 EVO Plus SSD 1TB M.2 NVMe
- $70 Alpenfohn Black Ridge Low Profile CPU Cooler - 120mm
- $20 Noctua NF-A12x15 PWM, Premium Quiet Slim Fan, 4-Pin (120mm, Brown) 120x120x15 mm, 12V, 4-pin PWM, max. 1850 RPM, max. 23.9 dB(A)
- $9 Noctua NM-AM4-L9aL9i, Mounting Kit
- $825 *approximate Total w/discount for new credit-card signup
