Discussion bmax 4k lag
graziano68
Hello
I bought a mini pc Bmax Maxmini B5 to replace my old Minix Android HTPC
Specs are
Windows 10 Pro
Intel® Core™ i5 5250U
Intel® HD Graphics 6000
8GB Memory and 256GB SSD
HDMI 2.0 / MiniDP / Type-C Video Output Ports
USB 3.0×2、USB 2.0×2
I upgraded OS to latest Windows 10 version and all seems to work ok .
However I am having big lag issues to play some 4K video HEVC x265 video such as the movie below
Video​
Format :HEVC
Format/Info :High Efficiency Video Coding
Format profile :Main 10@L5@Main
Codec ID :V_MPEGH/ISO/HEVC
Duration :2 h 13 min
Width :3840 pixels
Height :2160 pixels
Display aspect ratio :16:9
Frame rate mode :Constant
Frame rate :23.976 (24000/1001) FPS
Color space :YUV
Chroma subsampling :4:2:0
Bit depth :10 bits
Writing library :x265 3.4+32-b24459657:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings :cpuid=1111039 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default :Yes
Forced :No
Color range :Limited
Color primaries :BT.709
Transfer characteristics :BT.709
Matrix coefficients :BT.709
I tried various Windows players , VLC works better than others but it lags too .
I have seen that while the movie is playing CPU goes to 100% while VGA HD Graphics 6000 goes to about 50/60% .
Can you recommend something to run these 4K movies without lags ?
How to use HD Graphics 6000 at its maximum (100%) and use less cpu ?
If I switch from Windows to some OS Linux distro could I solve the lag problem ? Linux Mint , Ubuntu ?
