Black OSMI rev. 2 build
Vitamin Moto
33
45
www.youtube.com
I see. No idea though. There isn't any space left for mounting anything, so I would guess it's a manufacturing process thing.
I can see now that your cutouts are different than mine. It could be, that 1070 will fit through the holes. I would wait for the card, before unscrewing bottom plate.
Vitamin Moto
33
45
www.youtube.com
The optical drive mounts like this:
And K888D was right, those holes are for HDD/SSD 2.5" drives.
leonroy
27
32
Very cool to think that you can basically fit a Bluray drive, a 2.5", a 3.5" and a M.2 solid state drive into one of these cases. Probably weighs a tonne after everything's squeezed in there though!
Vitamin Moto
33
45
www.youtube.com
Seems like you have to choose right motherboard to fit these 2.5" drives inside the case. Usually 24 pin power connector goes right below where this 2.5" drive sits. This is not possible with my Asrock Z270 board. In the picture we can see, that 24 pin is at the "top" sort of speak. Also, BigShuriken cooler blocks 24 pin, if it's located at the top, how it is in picture.
With case so small, you have to check and measure everything, before buying stuff :)
alexep7
178
134
does the Osmi include an SFX bracket to cover that area if you're using an external PSU? I have the chance to purchase the case for relatively cheap, but I didn't want to spend more just to buy an SFX power supply...
leonroy
27
32
Nope. Have to get that custom made or just cut a piece of perspex from your local hardware store.
SiG
48
Where can one aquire one of these cases? They seem to not be available in the United States.
SiG
48
To the OP, would a Noctua NF-A15 PWM be a suitable substitute for a fan? I'm not sure what kind of mounting holes the OSMI uses for its case fan.
