Sooo I just ordered the Asrock A300W, and looking at all the components needed to build it out.
After searching everywhere I haven't seen anyone who has liquid cooled this little monster. I understand its due to size, but would it be possible to attach the cooler to the cpu, and the radiator/fan to the exterior of the case? Cut a hole on the case and install a grommet then run the hoses through it. Mounting the radiator wouldn't be difficult.
Is this possible? Would it work? Would it be worth the trouble vs just buying a Noctua NH-L9a AM4, 37mm Premium Low-profile CPU Cooler for AMD AM4????
Let me know what you think!
