Any good cases for Mini-ITX Build under 10 L
akisu
100
53
it's says 404 not found on sfflab e-store
Maybe it will be back on stock with sfflab 2.0? But I am not sure too.
Josh removed the shop from his webpage. But he wrote that there might come another batch in summer:
Dawelio
Awesomeness
503
427
Did you even read any of the posts in this thread, especially the ones by op?
I did read the OP post yes, didn't say anything about cost or so. Hence my post and then afterwards, I noticed OP mentioning budget of $1500 and later looked up the GPU in question and noticing it's cost.
So yes, I did read them... Just was a bit too fast on the reply button that's all.
ignsvn
By Toutatis!
1,621
1,538
On their website it says that the Modovio Xcase S is Out of stock, i'm trying to contact them via email but they dont reply. Do you know about the availability of that Case?
Do give them a while to respond. Situation is bad, so probably they're in a lockdown or something.
In the mean time, feel free to browse around :)
