Any good cases for Mini-ITX Build under 10 L
angga456
Since my desk can't hold a huge Full-Size PC and I don't want to spend my money on a Gaming Laptop. I always wanted a Mini-ITX PC Under 10L which will perfectly fit on my desk but I don't know any good cases for the build.
angga456
Thanks for the recommendation but I'm looking for something a bit thinner than that
ignsvn
By Toutatis!
1,621
1,538
.. and maybe you'd want to specify more details, like:
- what size of motherboard?
- what's the minimum CPU cooler height?
- what size of GPU? dual slot? triple slot? full height? half height? single fan? dual fan? triple fan?
- how many hard drives (3.5" / 2.5")?
- preferred PSU type? SFX, ATX, Flex, Meanwell, etc?
Reactions: Jello and rfarmer
angga456
I'm Choosing a Mini-ITX Motherboard
the CPU Cooler is AMD Stock Cooler (Ryzen 5 3600)
The GPU is MSI Aero ITX RTX2060 it's a single fan
I don't plan to have Hard Drive, I'm gonna choose 512 Nvme SSD instead
For this project, I'll prefer SFX Power Supply
Reactions: ignsvn
ignsvn
By Toutatis!
1,621
1,538
Around $1500
Sorry, I mean the budget for the case alone.
As you know, commercial cases usually cost like $50 and more. Now the custom cases here is another story. I'd say $150 onward.
Also, for the custom cases, depending on where you live, you may need to pay shipping fee as well.
ignsvn
By Toutatis!
1,621
1,538
ah for the case i think i won't spend over $100
Right. So I think we can rule out many of the custom cases here.
For the commercial cases, I'd suggest:
- Silverstone SG13
- Silverstone Raven RVZ01/02/03 series (or Milo ML08, basically similar)
- Lian Li TU150
- Cougar QBX
Please note that they aren't exactly 10L & some are probably slightly more expensive than what your budget allow.
akisu
100
53
if you have a $1500 budget you could spend a bit more for the case as your components are kind of cheap. I had a similar budget (just a different currency):
ProductCommentPrice
Skyreach 4 Mini40 Euro German Toll243,00 €
NFC Addons (cables, feet)24 Euro German Toll125,00 €
HDPlex 400 AC DC + HDPlex 400 DCadded C6 AC Connector193,00 €
Asus ROG Strix X470-I Gaming116,00 €
AMD Ryzen 5 2600 140,00 €
16GB RAM Ballistix Sport LT 3000MHZ CL153400MHZ CL1479,00 €
INNO3D GeForce GTX 1070 Ti X2 V21900MHZ UV305,00 €
1TB SSD Samsung 970 Evo m.2188,00 €
CPU Kühler Noctua NH-L9a-AM4use fan for GPU cooling40,00 €
Noctua NF-A9x14-PWMadditional GPU cooling17,00 €
Noctua NF-S12A-PWMuse as CPU fan11,00 €
Total1.457,00 €
dzjlimit
I would recommend a Velka 5 if you can find one on sale or order it next month. It is probably the smallest case that can hold these components at a relatively low price. (I own one and it is very nice).
angga456
ProductCommentPrice
AMD Ryzen 5 2600140,00 €
Total1.457,00 €
Hmmmm, where can i get the Skyreach 4 Mini, i've been looking on it for a while on the internet but i didn't find it.
