News AMD X570 ITX Motherboards
So we have 1 confirmed so far:
The Crosshair VIII Impact is the ITX variant.
I'm hoping here that Asus think Zen 2 is amazing enough to revive Enthusiast class Impact boards and not offer us neutered versions like the Strix garbage they've been peddling for the last few years!
B550 boards are "speculated" to appear around 6 months after X570.
bluestofblue
110
73
When the AsRock board drops there may be sales going on like right now with Microcenter to take $50 off of a board. This makes the x570 boards a lot easier to digest.
CantingSoup
190
100
Anandtech just posted their massive X570 mobo comparison this morning, and while there's no buy links yet for the AsRock ITX/TB3 board, they say the MSRP should be $300, making it $80 more expensive than the Gigabyte board. No MSRP listed for the Asus ITX or DTX boards. The AsRock Z390 ITX board is currently $180, so any price savings by going AMD over Intel CPUs is completely washed out by the x570 motherboard pricing. All the more reason to get a b450 board unless you have a really good reason not to, or wait for b550.
$300 for the Asrock board is a bit tough to stomach, but it's the only AM4 board that fits my use case.
Reactions: cmyk78
ermac318
655
510
Exactly, mine too. So I'm not comparing $220 vs $180 I'm comparing $300 vs $180, which makes it even worse for AMD. If Intel drops their prices in the next week or two like the rumors say they will, there's no question I'll go Z390 + 9700K over X570 + 3700X or 3800X. It's already mostly a wash in terms of cost, but Z390 is well baked and stable. It's just X570 is more future proof, since it's believed Intel will introduce new chipsets for Comet Lake with yet another socket variation.
ermac318
655
510
What would be the difference between the x570 and the b450/b550?
Unless you need PCIE 4.0 (you don't), a huge VRM for the 3900X or 3950X, or some other feature unique to a specific X570 board (like Thunderbolt on the AsRock X570 ITX board), there isn't a difference in the ITX context between X570 and B450. ATX boards there's a much bigger delta.
No one knows what B550 will look like yet for sure, so impossible to know.
If I wasn't set on TB3 then I'd just get the MSI B450 board, which has an outstanding VRM and supports PBO voltage offsets now.
Reldey
387
405
So found out this was a thing today: Link
Going to make the switch a bit cheaper.
TekEverything has a video on it from a couple years ago, not sure why I didn't already know about it. Guess it didn't seem worth it to switch at the time. Gonna upgrade from a 7600K.
prayogahs
236
343
I also bought the kit to use my L9i from i5-7500 to 3600. FYI, it seems Noctua can provide them for free if you contact them and show the original invoices of the L9i and Ryzen motherboards as linked below. Don't have experience with it but most likely will take more longer vs buying.
SuperShires
44
45
With X570 it would be simple plug and play, with B450 wouldn't you need an existing CPU to drop in so you can update the bios? pretty sure the B450 isn't plug and play and will require a bios update first?
ermac318
655
510
If you wait a few weeks, I'm sure most of the boards will get updated, or you can ask your seller to do it (like NewEgg, Microcenter, etc), or get an update kit from NVIDIA. After Ryzen 2000 came out a lot of older boards got stickers on them saying "Compatible with Ryzen 2000" and I'm sure you'll start to see similar stuff soon on older boards. But yes, if you just buy one blind you can get into trouble. There are many threads on this already on the forum if you need help doing it.
FCase
FCase
Dec 20, 2015
142
92
Historically, previous Strix "-F" and "-E" mobos were equal price and ~$30 higher than the -I, respectively. The X570-F is $300 and the X570-E is $330. OutletPC is the only site with a listing for the X570-I, and it's $300.
MFRP is $400! They are just selling it for $300! Hopefully the Biostar offering is as good and cheaper than ASROCK, ASUS, and Gigabyte boards. Might force prices down a little. Otherwise there is always the EPYC Mini-ITX server option. At least then there is a legit reason for the price.
Mal
  • Wow
Reactions: Acalanata
2,201
2,225
I did that a couple of months ago, was a problem-free process, the bracket arrived in the mail a week or two later. Used my Biostar X370GTN receipt (from back when that board was the only AM4 ITX option) and an L9i I bought this year for a separate project, and even with two years between the receipts everything went smoothly.
Reactions: prayogahs
Marvelm
232
106
Mal
Did Biostar confirm they're going to have a x570 itx board?
prayogahs
236
343
Nice! Thanks for the information. Unfortunately we cannot rotate the l9i using the am4 brackets to align the heatfins along the RAM and instead blowing air straight to it and the VRMs. Might be a little bit worse on temps but I will take what I can get.
Reldey
387
405
Yeah that's annoying, you would think Noctua would know better on their AMD specific NH-L9a, but oh well. It's either that or the daunting Blackridge for me, which has had some compatibility issues with the massive heatsinks they are slapping on these boards.
Hifihedgehog
Editor-in-chief of SFFPC.review
May 3, 2016
459
408
www.sffpc.review
ITX never really gets any savings for being smaller - usually you end up paying more due to the tougher engineering job of fitting everything into the smaller package. The Impact will definitely suffer this, being a flagship ITX board so stuffed they needed to make it DTX. ATX always scales higher at the high end, but the cheapest boards are usually either ATX or mATX too. I wouldn't be surprised at all if the Impact matched the prices of its ATX siblings, or even exceeded them. Still, I hope the Strix is below $300.
I will agree to disagree in this case. Historically, regardless of the form factor, the high mid-end ASUS ROG Strix boards have been less than their flagship ROG non-Strix boards by $50 to $100. I simply cannot foresee that precedent changing anytime soon given the gap in feature sets between the two.
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
Mal
Everything's fine. No seriously! Time and again, OutletPC has been notorious for listing exorbitant placeholder prices. They were pulling these same shenanigans before the pricing was confirmed for the Ryzen 3000 series processors. Looking at the other STRIX products, the X570-I might end up costing $299, but I am sure it won't cost more than that. Bringing this back down to Earth and centering this in reality, keep in mind that the Z170-based ASUS Maximus VIII Impact cost "just" $249 at launch several years ago. The Crosshair VIII Impact lacks many of the features of the other Crosshair models so it would be a stretch to wedge it squarely in the price point "round hole" of the ROG Crosshair Hero. And conversely, the Impact cannot be priced too low either and invade the lower-end (relatively speaking) ROG Strix products since it has more features than those products do. We will certainly see soon enough how this all shakes down in the weeks ahead!
2,201
2,225
You misunderstand me entirely. I was talking about price differentials between ITX and ATX/mATX boards in the same series, i.e. the notion that ITX will be cheaper (within its market segment) because it's smaller. That was the claim made in the post I responded to, which in my experience has never, ever been true. ITX is typically at price parity with ATX parallels despite less features due to less board space. Price differentials between series is another matter entirely.
Reactions: Hifihedgehog
