AIR cooled, Wall Mounted, behind LG C9 OLED TV, Nvidia GPU R5-3600cpu build questions
SprungNickel427
Hi SFF Folks,
New here, because I spoiled myself with a 65" LG C9 OLED, for my 50th Birthday, which recently achieved G-Sync Compatible status.
The TV is wall mounted with power and Ethernet all neatly behind and out of sight. I'd like to build a Ryzen 5 3600 Nvidia 2080 super, SFF build I could install behind the TV. Wireless K+M + Headset, Gaming at 1440p 120HZ G-sync enabled, to my new piece of art in the LG OLED C9 65" TV.
Behind my TV I have a 4" deep space and possible 9-10" height and 30" long to "hang" something. Is there a possible Air Cooled solution that can be wall mounted? Effectively completely blocking 1 of 6 sides of the box, because it's flat against the wall.
Budget for the build ~$2000, 1440p 120 HZ on high settings, Games include Sea of Thieves, BL3, Racing games, etc....
Sliger SM 2025 case perhaps?
Best Regards,
SprungNickel427
SprungNickel427
i’d Take a look at the hdplex h5 case, it’s semi passive cooled and has support for full height itx gpus: https://hdplex.com/hdplex-h5-fanless-computer-case.html
Or maybe the streacom fc-5 alpha which is pretty similar to the hdplex but thinner: https://streacom.com/products/fc5-alpha-fanless-chassis/
Thanks That Guy. I've been digging and see this Sentry 2.0 case is pretty slim. I can go very long and only restricted by the "depth" really. Much appreciated.
H5 is sold out and not really suited to high performance. the FC5 is even lower performance. I don't think a passive case with a Ryzen 5 3600 and 2080 super will work looking at the TDP Watt range these cases are designed for.
Reactions: ThatGuy333333
