Log 10900k + 2080 Super / Ncase M1 / Air Cooled / Build Complete Log
ghop
34
Aren't those Seagate 2TB 7mm? If so they should fit behind the front panel using the stacking bracket.
Well I knew I would feel dumb when someone eventually told me there is a way. I tried all the different brackets in all the different ways I could imagine. Of course I didn't bother opening up the manual. It's right in there. Okay, time to un-glue and do it properly. Thanks.
kanth
51
Do you really think you need that much voltage for 5.3?
I can hit 5.1 with 1.25 V Core with a badly installed AIO
ghop
34
For all core sustained?
Mine hits 5.3s two core and 5.1s all core for the short turbo intervals. But not sustained.
Sustained averages down to 4.8 long term.
Here are my bios settings. Maybe you can tell me if I'm overlooking something.
Aux
179
155
Welcome to my build log.
Hi
will you be submitting your build to the power per litre thread?
General entry rules
  • Picture of actual PC
  • Volume calculated as bounding box to two decimal places rounded up (with exterior dimensions of case WITH power brick(s))
  • Case maker, name and exterior dimensions (including feet) to be shown to calculate volume
  • Cinebench R20 must be run on CPU benchmark and screenshot must be taken with CPU-Z open on the first tab.
  • Time Spy on default preset and score is Graphics score, not total score.
  • Time Spy must have results page screen shot, GPU-Z first tab and link to result posted.
  • Round 3 PPL calculation ((CineBench R20 score * Time Spy graphics score)/(Build Volume^1.5))/100
  • This is a friendly competition, keep it clean and civil
  • Competition ends at 25 entries (new round with new benches starts after)
| Time Spy download link | Cinebench R20 download link |
ghop
34
Hi
Sure, I can. First, it looks like I have to install Steam and download 3d Mark @ 4.2gb. Then I will post results.
kanth
51
I got manuall OC for All cores at 5.1 with 1.25V you have your CPU ratios auto and your Ring Ratio at auto as well
