Hi, this is a version 2 of a case I designed.
This case can fit a atx psu for lower noise, higher efficiency, and cheaper prices.
Otherwise, the room left can be used to house a flex atx psu and two 120mm aios (with low-height water blocks)
Here is the specs of this case
flex atx with two 120mm radiators
default config (atx psu)
an optional handle for carrying
- width: 10.6 cm , height: 21.5 cm , length: 37.6 cm, or about 4.17' by 8.4 ' by 14.8' for American friends.
- volume : about 8.5 l
- motherboard : itx board
- max graphics card length : (220 mm with atx), (240 mm with sfx), or (330mm with flex atx, because why not)
- max cpu cooler height : 40mm , but just use nh l9 or l9i
- The length of the graphic card board is limited to 190 mm when you use liquid cooling (zotac minis fit)
- estimated price 200$~250$ , depending on volume
