I've been using the NFC S4 Skyreach case for my system for the past two years now, but i've had some recent issues with the power brick causing the system to crash. So with needing to address the power supply issue I thought what better opportunity than to do this and give a custom case another go.
The basic concept for the case is to have the motherboard and GPU back to back, with a SFX power supply below them. Please excuse the component scaling on the drawings as it is not 100% correct but hopefully it gives an idea of how the space is used.
My plan is to make the motherboard tray, top, middle, and bottom pieces out of aluminum. The front and back pieces will be made out of wood to add some colour and keep some symmetry.
The overall size at the moment is (LxWxH) 230mm x 130mm x 280mm - 8.4L, but the height will probably come down a little bit.
