Is a plastic frame strong enough?
Hey, you mentioned that the Enhance 7660B doesn't have pcie connectors?? I just ordered one and clearly in the description it mentions that there's a 2x pcie 6+2:
Enhance Flex power supply 600W.
Brand new with 1-year warranty.
20/24pin +(4+4pin) + 2 x (6+2pin for VGA) +3 Molex +1 FDD + 4 x SATA connectors
Why does the MicroRax suck? Been thinking about doing something like your project and liked how you can order the MicroRax cut-to-size.
You better post where you found itI just got my 7660B and I can confirm that it DOES come with 2x pcie connectors!
Here you go, I got it from eBay. I think they're on Amazon as well.
https://www.ebay.com/itm/Enhance-Fl...817076?hash=item4434ee6df4:g:ZtcAAOSwAclbhEik
@Andorski
I have these beams and they will def hold the weight.
@AURMEND
how are your side panels attached? (instead of being flat they have flanges on the side to attach to the frame?) how thick are the panels? what material/filament is it printed from? How strong are the pieces?
sorry for the barrage of questions lol, but this is very interesting
Why did you get rid of the aluminium extrusion? How does this affect sturdiness and cost?
I'm curious to see how this will work out, I'm thinking of doing a extrusion frame myself but if this works out I will reconsider 3d printing.This is just a prototype since the aluminum extrusion is the most expensive part. It's not meant to replace my original design
Sturdiness I have no idea but my guess it will be flimsy towards the middle. Total cost should be around $40 if nothing goes wrong with the printing process.
$20 for 1kg PETG or ABS
$5 for M3x5mm low profile hex screws
$5 for M3 low profile heat inserts
And 4 standoffs for the MoBo
I think that only the top and bottom panel have to be acrylic since they are more likely to bend.So it's possible to make any of the panels acrylic but not all of them. Just have to modify the file which will not be hard. Even on my original design you can do that for the cover.
If you want to make it fully acrylic just put the panels on the outside of the frame. It will take me a few hours to make it so.
