Concept 5.37L Aluminum extrusion Frame
AURMEND
Destroyer of PCs
A&M Solutions and Design LLC
Jul 30, 2018
249
222
Check the google drive folder, im adding components so you can make your own covers.
GOOGLE DRIVE: https://drive.google.com/drive/folders/1baZ41_omjnPZToynwCFiMvHn5-nhykog?usp=sharing
Components in the drive:
Frame: Makerbeam 1010
Top cover: Used so you can make your own cover or even use an Acrylic Sheet
Frame+Comopnents
Max GPU length is 215mm (Zotac 1080 ti mini)
PSU: FSP 500w GOLD Flex atx (do not buy the Platinum)
I will not be releasing the Panels since its still a work in progress. i do not have access to my 3D printer at this time.
Please feel free to download and make your own panels and post them here.
ALSO PLEASE POST SUGGESTIONS!
EDIT: Use this PSU to save you time and the hassle of sleeving the cables but the case needs to be slightly redesigned http://www.geeekstore.com/shop/custom-flex-atx-modular-psu/
Gautam
148
123
It looks very nice, and I always love to see flexATX concepts.
The pic is a little confusing as I'm not sure which is the GPU and which is the PSU. Where does the power plug go?
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
the GPU is in the back corner, i used a Gigabyte 1080 mini as a reference.
heres an earlier draft. the PSU is under the SSD
Reactions: rosinbole
SumGhai
147
175
Looks super clean.
Are makerbeams pre-tapped at the ends to fit those corner connector cubes? I was considering doing a similar project, but combined with some 3d printed parts to give it a different outward aesthetic.
edit: I looked through Makerbeam's catalogue to find that they *are* pre-tapped, that'll be super convenient.
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
I'm going to be uploudiup the frame with the SFX PSU later today.
EDIT: It should be up one the google drive
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
would this be a Would this be a good idea? 240x320x100= 7.68L
makes for a better CPU cooler and what not
Same specs different PSU layout but harder to work with
Here you go a video of the one on the first post
Reactions: Gautam
Gautam
148
123
The system in my sig uses my case with a similar design. But 320mm is nearly impossible; 345mm or so is the absolute minimum when the riser and PCI-E tabs are taken into account, unless you let the riser go over the motherboard.
The layout after it would be perfect for sticking a radiator on top...up to 2x140mm if done properly. That could be very interesting.
240mm is an odd length, though. It's not enough for a full-size GPU, but is a bit "too large" for mini ones.
garyroks
51
23
1010 aluminum profile quite hard to get. how to you manage to get one ?
i used a 2020 aluminum profile to make my SFF case.
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
There's only 2 manufacturers, MakerBeam and MicroRax. MicroRax will be cheaper because of the precut lengths.
My first design from over a year ago was using 2020 but i was wasting over a liter of space so now to make it smaller
Sp4m
This is beautiful! I'm working on something similar, and this is a great inspiration.
Also, thanks for sharing that PSU. I wasn't aware of it, and I think it could be perfect for me.
CC Ricers
2,234
2,557
This can turn out to be a good alternative to GEEEK cases if you can customize the panel materials and size of the case. 10mm beams is also less added bulk compared to 20mm, important for cases this small.
ckaym
Yes I spent days until I found Makerbeam make 1010 T/V-slot profiles
There are re-sellers, but I found their original shop www.makerbeam.com to be the best considering prices & availability.
Though shipping (within EU for me) could be cheaper (it's 15eur), still it's ok if you can get everything you need in one order.
Btw I found also Makeblock make some nice Alu-profiles with various & thinner profiles like 0412, 0808 & 0824, that also seem to be compatible with each other. Also the 0412 has a 1mm groove, so when you mount it to a 0808 profile it only adds 3mm extra thickness.
Makeblock seem perhaps a little more expensive (not too much imo), but most re-sellers have some parts out-of-stock that you might need to wait a month or so until delivered :/
Makeblock's EU site (if that's your area) is to be opened soon (whatever 'soon' means), but I think
https://shop.maker-store.de/robotik/mechanische-bauteile
and
https://eckstein-shop.de/Profile
have decent stock & prices.
I don't know if these are the best shops to order online (esp. for everyone's location - perhaps not), but I share them as a faster starting point (comparison) - no advertisement intended! :)
If you know better online store for EU, please let me know!
Cheers!
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
and
Cheers!
Hmm I need to look into this.
SumGhai
147
175
I took a look at that ChartUp site you linked in the google drive folder. Would you happen to know any similar services in the US? I tried looking into MicroRax, but their website is very inconsistent for me, and I don't know if they also tap or cut threads into the ends of custom cut beams.
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
As far as US sellers, it's only MicroRax(their website is highly unreliable), they don't tap them due to the different style of aluminum extrusion. So they use corners like this.
SumGhai
147
175
Aw that's disappointing, I wanted to try out an idea inspired from yours but with using the threaded ends of the beams to attach the acrylic panels. I'll probably send an e-mail to ChartUp later to see if they might ship outside the EU.
