Hi Everyone,
I am a newcomer to the small pc crowd, but with the release of the AMD Ryzen APUs I thought I could give it a try.
I built the PC around the Intertech XJ500 itx case: https://www.inter-tech.de/en/products/case/mini-itx-nuc/jx-500.
Since the case is meant for ATOM-based itx machines, the 60W inbuilt DC power supply is of course insufficient. Therefore I bought a Mini-Box PICO-PSU-160XT (link) to go with the machine and an external power brick from Leicke capable of 192Watt (link).
My current issue is that the 192Watt brick comes with a 4pin ATX 12V connector (similar to this), but the case only has space for a 5.5 mm DC connector in the back.
I have searched for 4-pin to 5.5/2.5 DC adapters, but have not been able to find them in retail. Is it really necessary to pull an extension cable of 4-pin (female->male - connected to the external brick) through the whole in back of the the case to connect directly to the 4-pin (female) connector of the picoPSU? There must be a more elegant solution than having an extension 4-pin dangling outside the case.
Alternatively, I was thinking it might be possible to construct the adapter myself. Simply modify a cheap extension cable (like this) and attach a 5.5/2.5 jack (like this) at the other end. It would just extend the external power brick cord a little, but otherwise my case would be unchanged. I am unsure if this is actually possible given the rated specifications of said 5.5/2.5 DC jack is 25v/4amp.
I hope that made sense and that some of the smart people in here may be able to suggest solutions (or inform me whether my suggested solution can work).
Thanks.
P.S. In case PC specs are of relevance: Ryzen 2200G, Noctua NH-L9a, 8GB of Corsair LPX3200mhz, 120GB Kingston SSD, Asrock AB350 Fatality itx (Wifi) (Bios 4.50).
Thanks.
