as above, love Loque's Ghost S1, dont like the price or lack of being able to handle a 3 slot GPU , any form of small ATX PSUs or 280 slim AIO to handle the heat of coffeelake without having to delid- or use a slightly larger low profile cooler .
Suggested to Loque that they Steel plate and press and cheaper version for OEM/budget owners- some reason ITX case makers think every ITX owner has a large bank account
so, friend should be able to print this off cheaper then the PCEi cable riser....
Unlike Ghost S1, the spine will be in 3 pieces- friend highlighted less error issues and quicker/easier to print if its in parts.
I've just done rough cad models but he'll do proper ones to use for printing . Believe he wants to lock the mobo plate via T piece/slot into the front/back pieces. Sides will be Acrylic and top hats printed. He stated mobo panel will be high heat resistance 115c material and the other parts 60c
Unit will house 280 AIO also CAD model of Alphacools unit was the UT60 280 haha so bottom hat is a little large .
Could only find/make basic models of SFX and small ATX PSU units- work PC is too poor
might- just might see if we can squeeze a bitfurcation GPU set up in - might work with Dual slot only cards...
See the layout between SFX and ATX PSU
and bequiet 140 fans attached
seems he just landed a job today at a metal press plant ... hahaha
He also has a Zotac gtx 1080 AMP Extreme 11gbps to test if it can house a giant GPU beast
again this is a CLONE suited to my needs fair play to the stunning design of the Ghost S1!
