30 liters 8x GPU mining case
duniek
55
156
quick plug in and works - next week cable managment + I am waiting for 45mm standoffs to use between cards
ChainedHope
306
459
What kind of black magic is this. I want to see the files for that laser cutter. I might be tempted to get my own version cut at the local shop... I really like how everything just sort of bends in place. Its giving me some ideas for an open test bench...
Reactions: cmyk78
duniek
55
156
between bend spots I made 1mm wide hole gap to make bending easier, its possible to bend by adjustable wrench tool or even in fingers
owliwar
Lazer3D
Apr 7, 2017
586
1,082
wait a minute
are you mining on low profile cards?... srly?
othen than that I like the way you designed these
duniek
55
156
wait a minute
performance is the same as normal card, I bought them at shop where I have 10% discount code which was valid for only 2 days, also this model was on additional 10% discout so about 20% cheper than regulard cards so I give it a try
Reactions: cmyk78 and owliwar
ChainedHope
306
459
Very nice. I've never thought of getting a few pieces cut and then bending myself lol... even though i did something similar in an older build with some aluminum to extend a case (bought a bar and hand bent it around a jig, then screwed it on with some angle brackets)... I'm going to see what I can come up with for a test bench and get it cut out. Looks like a cool way to do it and I need a new bench anyways.
duniek
55
156
next project in progress - 26 liters - 12 GPU (total fans - 7) - power consumption 700W
no renders :(, i am poor at this
Reactions: cmyk78
MarcParis
Apr 1, 2016
3,723
2,865
27,5 liter (size of fractal nano s case)
12x gpu mining rig powered by 1600W gold lepa psu
easy can be converted to NAS 12x HDD case
even atx board will fit (220mm wide max)
Tons of stuff crammed in this box!
gg!
