30 liters 8x GPU mining case
duniek
55
156
This is 30 liter case - dimensions ~ 30x25x40cm
specs:
i5 7500 (i know i should use celeron) but i bought whole set (mobo cpu ram for cheap)
8gb ram
msi b250m pro-vd + 2x pci-e expander 4x riserUSB
660W seasonic platinum
custom cables 2x (EPS 8pin @ 4x riser)
3x 120mm corsair 0,25A fan (@ 5V) very silent (even for 7V) - I can sleep 50cm of it - no problem) - also perfect for cat ppl - lol (top of case about 30*C)
8x 1050ti (7x kalmx + 1x zotac - i have 8x kalmx but i have probably damaged riser - when i plug stormx or kalmx gpu in there - no boot and squeeky noise from riser - with zotac no problem) - it will be replaced after I made panels
total power consumption 470W @ mining ETH
I know, I know - You will say - this is OVEN - NO SPACE GPU - WROOOONG - NO - I made project especially for 1050ti - each consumpt about 56-58W - temps are low - sth about 50/50/55/55/65/55/50/50*C (this 65*C is probably middle card in "dead zone" of fan but work OK)
- TO DO LIST:
- front panel/other side panel
- expander @ riser to prevent stick out of case (or resolder USB connectors for angled ones)
- PS (i have next project coming soon) - 30liters as well but maybe i can fit 12 gpu ;)
KMPKT
3,382
5,935
Large form factor and GPU mining :(
Jello
376
163
To be fair, if you compare the Nano itx to most cases user here have, there's nothing small form factor about it lol.
Kwirek
186
198
Looks like a nice and clean build with quite a lot of components for the form-factor.
Don't mind the mining-haters, they are obnoxious sometimes but most are just frustrated people with a heart of gold. :-)
Reactions: Josh | NFC
AleksandarK
/dev/null
May 14, 2017
703
774
Very efficient use of the space!
Even tho not SFF(SFF is <20 Liters), it is definitely space efficient.
What is the total hash rate and what do you mine?
Arboreal
805
803
fractal itx nano is 27 liters and can fit 1 gpu
but i apologize - please remove if it doesnt fit there
Nice answer! XD
I really don't like the Fractal Nano for its space inefficiency [Manta and Evolv ITX are worse though...], so what you've done in 30 litres is amazing.
GLW mining, the prices really are a rollercoaster ride at the moment... hang in there.
Reactions: Soul_Est
stree
307
177
Welll, at least mining isn`t artificially driving up the price of GPUs...............................
duniek
55
156
I made some cad drawings but I don't know if i thought about everything
if yes, there will be 3 cases but totally different look than this one
- 8 gpu low profile 13,3 liters
- 8 gpu regular 16,8 liters
- 12 gpu regulard 24,8 liters
all designed for low power gpus (1050ti/rx560)
Reactions: cmyk78
wywywywy
272
219
Very cool! :)
Definitely SFF compared to all the other 8x GPU mining rigs!
Do you have any pics during construction to share?
duniek
55
156
nothing much to see bcoz all parts (panels + alu profiles are ordered) laser cut + manual lathe)
I only do cad drawing + some manual drilling + m3/m4 threading profiles
but next week I will get front and side panel from laser shop so then I will make pics from inside
also one more pic (better screws)
and temps
duniek
55
156
case is made from alu 10x10 solid profiles + laser cut 2mm alu panels
this is pics from bigger one
but the same layout (just shorter) and fans are on side
Reactions: owliwar
