I'm starting a new build with an AMD processor, and my first main system to have one since having a Phenom II. It's a pretty modest rig with a B450 motherboard and Ryzen 3 2200G which I picked up for some good prices.
Here are the complete specs of the computer as it is right now:
- CPU/APU: Ryzen 3 2200G with Vega 8 graphics
- Motherboard: Asrock B450 Gaming ITX/ac
- Memory: 2x4GB Crucial Ballistix Sport LT DDR4-2400
- Heatsink: Zalman CNPS2X with AM4 adapter
- Hard drive: 500GB Western Digital Blue SSD
- OS: Manjaro Linux 20.1 (and later dual-boot with Windows 10)
- Power supply: HD-Plex 160W first-generation with 150W Dell Alienware AC adapter
- Case: Custom built, aluminum
The case built around it should be pretty small and meant for APU-only builds, but with some extra space to allow internal power supplies and at least one 2.5" hard drive.
I plan to go brick-less with the build later to make full use of that case. The CPU cooler might be replaced later with a DIY passive heatsink setup if I find temperatures to be good. So some undervolting would be done. The 2200G isn't something most people intend to overclock on the CPU side anyways, as the focus tends to be on overclocking the RAM for gaming.
