D
Deleted member 18826
Guest
I'm traveling for Christmas, so I won't be able to post too frequently. Apologies for that.This is the 7800MT that worked with everything and Ff demo just fine,except 3dmark....If you guys have any suggestion what else to change to improve it please let me know
The error below its not from the oc,the program itself got corrupted.I leave it here in case its useful to someone else...
I was not able to run 2400 FCLK stable with my 8700G, not even 2266, and I get more performance with 1950 FCLK at 7800 anyway probably due to be running in sync UCLK, so I would try that (you don't have 1950 FCLK option in the OC Tweak menu, so leave it on Auto and set 1950 in Advanced - AMD overclocking - PBO menu - Infinity Fabric; you also have Nitro settings here).
Your timings look good.
Some people need to increase VDDP at those speeds (I definitely do with Dual Rank memory), so if you still have issues try with 0.9v or even 0.95v. I read from Veii that it is safe up to 1.3v, but people usually stops at 1.15v.
Some people need to have a delta between VDDQ and VDDIO (VDDIO around 50-100mv less than VDDQ).
At those speeds you may need to start messing with the impedances, ASRock memory training doesn't test all values, check what I had to modify in case you also need to change any of those values to something that is different from the auto training.
I would also enable DFE 2D training and Nitro 8x/8x, it is supposed to help with training at high speeds at expense of longer boot times.
I would try running MT5 for for 25 cycles several times (should be less than 1.5 hours for 16GB) and follow the spreadsheet in case you encounter any error in one of the tests. You can find both the spreadsheet and the program in this post:
Leaving FFXIV Dawntrail Benchmark running in loop overnight is also a very good way to test stability
