Okay, I've finally made some progress with my old build. I've made the cutouts for ventilation in the other side panel (quite much work without a CNC ;P).
I was originally planning to use a thin fabric mesh as dust filter, and mount it to the back of the panel, but I think perhaps the GPU fans are a bit too close, and need the cutouts to be unobstructed? I might just place mesh in front of the radiator, since it is rather ugly to look at through the panel.
My plan further is to round off any uneven details, sand and paint the panels.
My thougths thus far is I'm okay with the result. I think I will make another go at the design more similar to the PC I made for my father in law (FarmPC
https://smallformfactor.net/forum/threads/farmpc.18103/). I will have to make it a bit wider though, perhaps 20mm, but that will benefit the intake fans a lot i believe.
I also plan to increase the thickness of the aluminum panels to 2mm (instead of 1mm) to get a bit more rigidity, and potentially use magnets instead of screws for the mounting mechanism.
Cheers Andy
