Finally built a new high end system after almost 9 years away from the hobby. I used a NOS (new-old-stock) Silver NCASE M1 v1, First Edition I had in storage that I got after backing the original Indiegogo campaign in 2013.
Back then I bought one of each color offered thinking I was going to upgrade more frequently. The black NCASE M1 is still running an old Ivy Bridge Core i5 system I migrated into the case back in the day.
Even with all this high end stuff crammed in, the layout is surprisingly roomy and no bunched up cables between the radiator fans and the components. Lots of unblocked/line-of-sight airflow between the radiator and the cpu/mem/mobo/psu. I just used the cables that came with the Corsair PSU, the platinum series PSUs come with extremely high quality cables, I was very impressed. Just took some work routing everything.
The only snag I ran into was that I messed up plugging in the front USB 3 header and messed up a pin on the motherboard. The front USB 3 cable and plug are so thick and more difficult than I remember to plug into a densely packed motherboard.
I realized don't need or use front I/O anyways so I just removed the cables and ports from the front of the case, so now I have USB A and mini-jack shaped ventilation holes .
I seriously hope that the new front I/O setup for the V6 will be eventually be sold separately so I can get that clean, power-button-only look on the front. If I didn't have this first-edition M1 sitting around, I would have totally purchased the v6. Great case, thanks wahaha360 and Necere for all the work that went into it.
Specs:
NCASE M1 First Edition (Silver)
Core i9 9900K
G.SKILL TridentZ RGB Series 32GB CL 14-14-14-34
ASUS ROG STRIX Z390i
NZXT KRAKEN X52
CORSAIR SF750 750 Watt PSU
CORSAIR MP510 1920GB NVMe PCIe Gen3 x4 M.2 SSD
NVIDIA GeForce 2080 Ti FE
2 x Noctua NF-A12x25 PWM Fans
