Hi all,
I've been trying to design a uATX case on and off for about the past month after being inspired by this post, but no matter what I do, I can't seem to get it under 25l while still keeping all the components I'd like to.
So, solution: itx (!).
Because I lack funds, I decided to try and design a case that would be fully 3d printable (like the uATX case), fit 3-slot full-length GPUs, an HDD, an ATX psu and a Cryorig H7 on top for cooling. So far I've ended up with this: (grey blob is the hdd)
you might notice that it's flipped. I decided on this because I wasn't sure if PLS plastic could support the big hulk of a PSU (compared to sff psus) without bending or snapping. The only thing I'm concerned about with this is that the GPU might not be supported well enough by the back and the mobo.
the fan at the bottom is 140mm in order to exhaust both the cpu cooler's air and whatever air it sucks up from the gpu.
the finished product should look similar to the finished uatx concept below (designed because I am too poor for a cerberus).
any thoughts? is having it be inverted better or worse than having it be normal?
