I've been following mini-itx advancements nearly 10 years now but only finally managed to put an actual build together. My original concepts for a case were no longer relevant as they relied on a thin-mini board utilizing Intel graphics. So now I'm making a mini tower, which I thought would be the smallest case out there containing a GPU and water cooling until I started looking at these custom build forums. Yall showed me up and I haven't even finished yet!
I'm calling this a prototype because I honestly don't know if I'll like it when it's done. I'm using acrylic which is a new medium for me and outside my comfort zone. Wood is likely to increase my overall dimensions by about an inch on each side and I didn't want that. I'd prefer metal, (metal fab and welding was my military profession) but I don't have access to all the same equipment at home that I'm used to. So let's try something new!
My original design was 7" x 12" x 8" (WxH) but after actually laying out the components I'm widening the box to 8" and possibly extending the depth due to the PSU I bought. It's about 1.5" longer than the old seasonic I measured in my early blueprints.
Parts:
Gigabyte GA-Z270N-WIFI
250GB Evo 960 NVMe
32GB DDR4-2400 Ballistix
EVGA GeForce GTX 1060 6GB
SeaSonic 650w Prime Titanium
Corsair H55 cooler
(Additional HDD TDB)
The PSU is overkill, I know. I went to the store to buy a smaller one, but the website was incorrect about their stock, so I grabbed this one.
Motherboard tray
Initial layout
So far so good.
I didn't take a close enough look before cutting.The 4 holes are not all the same *facepalm*
I drilled holes to place the standoff screws on the thicker acrylic sheet (this will be the case side) which the motherboard tray will set on. And then the last screw snapped as I was screwing it in!
So I had to drill out the hole again (luckily brass is soft and drills out easily). Although, putting in a new screw then gave me another problem, the acrylic cracked!
The screw at least feels secure and everything lined up perfectly. This is actually a horribly planned build because I'm basically making it up as I go. Normally I'd have everything pre-measured but this I just sorta line parts up, make a mark with a sharpie, then cut/drill.
On a side note, always wear eye protection when cutting acrylic. Trust me, a hot piece of plastic in your eye doesn't feel good! But my jigsaw does cut the acrylic easily and leaves a nice clean cut. My table saw blade would likely be too aggressive for this material. The back of the case is actually polycarbonate, not acrylic like the rest will be. It's also only 0.093" compared to the 0.22" acrylic.
I'm open to suggestions on working with acrylic, such as best way to glue it together?
Parts:
250GB Evo 960 NVMe
Corsair H55 cooler
Motherboard tray
Initial layout
So far so good.
