Hi All,
I'm toying around with designing a SFF case out of laser cut perspex, and was thinking of using Parvum's Modding Cubes to secure the sides together.
However, in true SFF spirit I'm trying to cut every last mm out of my design and really want something just a tiny bit smaller.
Parvum's cubes are 12mm diameter, and I really could use something identical in function but in a 10mm diameter. The only ones I've managed to find online have been 10mm with only 2 sides tapped or the original 12mm size.
Does anyone have any secret suppliers, or am I doomed to try and fabricate these myself with some 10mm square aluminium bar?
