WARNING: THIS GUIDE DEALS WITH DANGEROUS ELECTRICS! ALWAYS UNPLUG A POWER SUPPLY BEFORE DOING ANYTHING ON IT, ALWAYS PLAN WITH SAFETY IN MIND AND DO NOT OPEN A SERVER POWER SUPPLY!
I needed an external brick able to provide 400W at 12V, with potentially 550W when I upgrade my GPU. I ended up modding a 750W server PSU... and it even works! With 750W max, the 400W peak I currently pull doesn't make the fan spin loud, it's just a low hum, barely audible even at 400W load.
PARTS:
PARTS:
- server PSU, HP 750W in my case, around £15 on ebay
- around 1800mm of 10 AWG cable (e.g. 900mm black, 900mm red)
- I used https://www.wirebarn.com/Wire-Calculator-_ep_41.html to calculate required wire thickness
- around 2000mm of 18 AWG cable
- on/off rocker switch
- 2 pairs of XT90-anti-spark connectors
- that's why 1000W max - XT90 is rated for continuous 90A current
- 1 pair of XT60 connectors
- around 1500mm of expandable cable jacket (or 900mm of stiff one)
- shrink wraps
- hot glue gun
- loctite / super glue
- liquid tape
- soldering iron
- snipe-nose pliers
