Resource icon
.STEP Mounting Plate for Panel Mount 6-Pin Molex Connector 002
This part is intended for using the HDPlex 400W AC/DC unit as a power brick for the S4M. A 6-pin Molex Mini-Fit Jr connector installs to this plate on the rear rectangular cutout. The 6-pin DC output of the HDPlex 400W AC/DC unit then plugs into the panel mount connector, which is connected to the DC/ATX unit inside the enclosure. This part could be used on any case that uses a similar cutout pattern.
5000 series Aluminum in 2.6mm thickness works well for this part. Warping when laser cutting is minimal, the threads are easy to make, and it can be finished any number of ways.
ZIP File Contains:
- .STEP 203 File
- DWG File (for SendCutSend)
- Solidworks Part
- Solidworks Drawing
Changelog:
R2
- Loosened tolerance of cutout dimensions. Very difficult to install the molex connector on R1.
- Slightly larger base material to reduce deformation of aluminum when tapping.
R1
- Initial release/test
Author
enricko7
Downloads
Views
1,349
First release
Last update
Rating
0.00 star(s) 0 ratings
