Resource icon
.STEP Mount Plate for HDPlex 400W DC/ATX module 2
This plate is to be attached to the backplate of the HDPlex 400W DC/ATX unit. It can then be rigidly attached to the inside front panel of the NFC S4M. Use 90 degree countersunk M3 screws in 4mm length for best results.
ZIP Folder Contains:
- .STEP 203
- .dwg file (for SendCutSend)
- Solidworks Part
- Solidworks Drawing
Changelog
R2
- Change material thickness to 2.6mm. This allows proper thread engagement when attaching to the S4M. When cutting, use this as a minimum material thickness.
- Change chassis mounts to two separate locations. Allows for fine adjustment of location, but is intended for two primary locations.
Location 1: Places the DC/ATX unit as far to the 'right' of the front panel as possible
Location 2: Places the DC/ATX unit as far to the 'right' while still allowing use of the standard power button location. This position should not interfere with standard mounted PCIE cards. (The use of a shift bracket with a longer gpu may cause part interference.).
R1
- Initial release
Author
enricko7
Downloads
Views
2,133
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from enricko7
