Minimised Acrylic Top for 4090FE/ Corsair HydroX Water Block
.STEP Minimised Acrylic Top for 4090FE/ Corsair HydroX Water Block 1
A redesigned acrylic top for the Corsair HydroX 4090FE as featured and tested in this build here.
3.5mm thinner than Corsair's original part, with G1/8 screw terminals directly integrated into the cover, making a separate port module obsolete.
For machining in Acrylic, Copper with Nickel Plating or Acetal.
Author
petricor
Downloads
24
Views
1,358
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from petricor
