This is a ~4L case, designed with a bent aluminum front/top/bottom panel, and a flat lasercut rear panel out of whatever material you'd like. The spine can reasonably be made out of any 1.5mm metal you'd like.
I will get a list of specific unique parts needed, like the riser etc to make this work, but I don't expect anyone will actually replicate this thing.
Though I will say it's a lot more buildable than my last case!
