Power Supply · ZF240 Fanless []240W[] ZeroFlex PSU
Extol 3D
Hello to everyone, I decided to create an account as I am digging this forum quite a while now and seems a great community backing immersive skills on SFF builts.
So I need to power my pFsense [VGAless] box and I need some guidance if you kind sirs may provide.
I am currently looking at ZF240 which I can not find anywhere reviewed or dissasembled if only a picture as seen on techpowerup.com forums.
At demensions of 139 x 86 x 47(LxWxH) we are looking at ~0.56L which is pretty solid.
They also mention 94% efficiency at 240w fanless.
Anyone here as an experience with this certain unit?
Any input is highly appreciated.
Again, Glad to be here folks! = ]
Thehack
Creator
Mar 6, 2016
2,818
3,673
J-hackcompany.com
Pretty uncommon unit.
If you're just doing a pfsense box, why do you need that psu? It's not a flex unit and you'd be paying for compatibility with the streacom case.
You likely won't find anyone who has bought that one.
Stevo_
449
304
Are you actually looking for a fanless flexatx?
Extol 3D
After some days of reading you are totaly right my friend. So I was reading your 12v PSU guide and I figured I can make use of this great write up. I am no expert when it comes to electronics but I have a close friend who works as electronic engineer so he will help if I am to take this path of solution.
Now what I want to mention is that my Lian-Li PC-Q07B case is desinged for ATX but I do like to have motherboard clearanse and I consider using the top space which is given for CD-Drive (I will not use one). This is like 19x19x5cm so I have space for FlexATX / U1 etc. My built does not consume over 60 watt (I do not care for extra watt overhead except that means drop in efficiency which kinda always does under 30% load) so I am interested in a solution that provides top notch efficiency + quality components (my budget is up to ~140e). Right now I am looking at a Seasonic SS-350M1U + noctua fan or the PicoPSU + MeanWell solution. Whats your opinion on Cosel / TDK-Lambda PSUs? I live in Greece so I do am restricted when it comes to distributor choices.
paulesko
415
322
Which cosel and tdk-lambda do you refer to?
There are also Delta 12v ac dc units which look very good and you can couple them with a pico psu.
