If not I will post the full article after figure out how to upload media in bulk.
Please read the the full article in the link to my notion blog.
Abstract
I was planning to complete this build in FormD T1, however during the time I was waiting for the preorder, I found ZS-A4-V3 on TaoBao. It offer a similar mechanism allow user to select a CPU cooler high/GPU thickness ratio, GPU size up to 315mm145mm59mm and CPU cooler up to 65mm can fit in this case.I mostly satisfied with this outcome, the system is quiet for web browsing and simple task, with really nice performance in gaming.
But I didn't expect the turbulence noise from CPU cooler can be this loud due to the fan very close to the side panel during heavy load and gaming.
I have switch to IS-47K as CPU cooling. see updated link in the abstract in the link below.
ZS-A4-V3 8.6L My cat-size gaming build
A new tool for teams & individuals that blends everyday work apps into one.
www.notion.so
Here
