Hi everyone,
I’m building my first sff pc in a Dan Case A4 V3 as a portable gaming rigI first went for a Streacom DA2 as it was more readily available, but was getting very high temps (~92C after 20 Minutes in Star Citizen) with this configuration :
CPU : Ryzen 7 3700X
GPU : Rtx 2070 Super 8GO Windforce
Motherboard : Gigabyte x570 I Pro WiFi
PSU : Corsair 600W Platinum
Ssd : Aorus 500GO PCI-E 4
Ssd : Samsung 970 Evo Plus 1To
Since then I took it apart and sent the CPU, GPU, Cooler and case back. I found a deal for a used Dan Cases A4 V3 which I’m waiting for. I also got the Asetek 645LT and custom cables from Pslate on the way. However I need to chose a new CPU and GPU that will keep temps down. I never had to deal with temperature before, as I was mostly doing ATX builds. I’d like my temps at idle to be around 40-50C (even lower if it’s realistic). My goal is also to fit a 2070 super inside.
So I’m considering a Ryzen 5 3600, since I read that the Asetek 645L should keep it cool. Should I look into an I5-10400 instead ? (I can still change the motherboard, although I don’t know if I can use my Gen 4 M.2 on a Gen 3 Port, so perhaps I’d have to change that too).
For the RTX 2070 super : should I go for a blower style Asus 2070S Turbo or an Super 2070 Mini from Zotac ?
CPU : Ryzen 7 3700X
