Hey I've been gathering parts for my next build and i have everything other than the GPU. I am going for an all watercooled build and have been looking at the AMP over its pre-watercooled friend as it has a higher clock speed (and I actually stand a chance of finding one in the UK).
Unfortunately I cannot find a waterblock for it specifically. Hopefully with your better knowledge in the subject you will know the answer to the following: Will EKWB's EK-FC GeForce GTZ FE fit on it? (https://www.ekwb.com/shop/ek-fc-geforce-gtx-fe-nickel)
It is apparently compatible with the TI blower from Zotac which is of similar size. If anyone can answer or offer decent alternatives that would be most appreciated!
